Radio.electro-music Itunes Listing!
Page 2 of 2 [30 Posts]
Goto page: Previous 1, 2
Audio files: 278
PostPosted: Wed Nov 11, 2009 7:44 am    Post subject: Reply with quote  Mark this post and the followings unread
If you open a new page in Safari and then type :
http://radio.electro-music.com:8050/listen.pls
for the URL it should work ... it does so here at least .. and it should be able to play the radio in the background then so you can start another app as well.
Other port numbers will work as well BTW.
Edit : the iTunes radio list does not seem to be available for the iDevices.
Audio files: 276
PostPosted: Wed Nov 11, 2009 8:01 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks, I'll try this tonight Smile
Audio files: 276
PostPosted: Wed Nov 11, 2009 5:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
it didn't work, had to use radio box
updating now to see if that helps
Audio files: 276
PostPosted: Wed Nov 11, 2009 6:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
works now Smile
Audio files: 278
PostPosted: Wed Nov 11, 2009 7:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
Cool
