paugui
Joined: Jun 28, 2008 Posts: 555 Location: Marinha Grande, Portugal / Oslo, Norway
G2 patch files: 37
Posted: Sun Jan 02, 2011 9:51 am Post subject:
paugui wrote: | Here goes my set
Will upgrade some info about it later |
I was afraid editing the post could imply to upload the file again, so the info about the set (and some photos), go in this post instead.
I used an Hartmann Neuron, two Nord Modular G2X (one for sequence duties which also made some percussive sounds and the other for some filtered drones), a Yamaha CS15 (processed by an Ibanez AD202), a Korg Trident (processed by a Roland SRE555) and a Roland V-Synth (only used patch 25 from OS2.0, V-Bamboozled), as well as a Novation Supernova II (rack) and a Novation Super Bass Station, both sequenced by one of my G2Xs.
I connected my Korg Polysix to one of the G2Xs but I don't think it was working ok (I was having some power failures, so only decided to turn that on a while before the concert and didn't have enough time to check it properly), so it was virtually unused.
All these synths were then connected to my Korg Zero 8 (from which I only used the Loop Delay effect on my Hartmann Neuron).
The Zero 8 Send 1 was connected to my Roland R880 which was used to add some reverb.
The mp3 file was captured by an Edirol FA101 and recorded in Garage Band, while the stream was captured by my Roland SP606 and streamed over Edcast.
Here are some photos I took today (the setup looks the same as two days ago ).
Hope you enjoy the mp3
Description: |
Korg Trident, Yamaha CS15 and Roland V-Synth |
Filesize: |
3.03 MB |
Viewed: |
637 Time(s) |
Description: |
Filesize: |
3.04 MB |
Viewed: |
626 Time(s) |
DES
Posted: Sun Jan 02, 2011 2:24 pm Post subject:
EdisonRex wrote: | DES wrote: | Arrrrrrgh...
Max upload limit of 20 meg.... and I havn't loaded anything yet...
Can a moderator fix this so I can upload my NYE set? |
bumped you up to 200mb and 50mb PM upload. |
Thank you sir! _________________ Dave
www.davesneed.com |
DES
Joined: Mar 28, 2006 Posts: 1356 Location: Kansas City, Mo USA
Posted: Sun Jan 02, 2011 9:16 pm Post subject:
Kevin Kissinger -- New Years Eve 2011 Improvised set |
Hi. Here is my improvised set from New Years Eve. This list indicates the modules that I showcased in the various sections of the set:
00:00 Voltage-Controlled Ring Modulator (fonitronics)
09:30 Karplus-Strong VCO (Les Hall) and Klee Sequencer (Scott Stites)
20:45 Super-Psycho Modulation Source (Ken Stone - CGS)
27:00 Wave Multiplier (CGS) joined by the Bi-N-Tic filter at 36:00
38:00 Bi-N-Tic Filter (CGS) with Klee Sequencer (Note: I did NOT use a phaser on this track -- you are hearing the Bi-N-Tic)
43:00 The Mega Percussive Synthesizer (Thomas Henry) joins in a plays a drum solo, of course!
45:15 Pulse wave processed through the "Grinder" (CGS) with Aries VC Low-Pass filter
48:50 Modulo Magic (Ken Stone - CGS) with the Klee Sequencer
56:00 Reprise with the VC Ring Modulator and some other sounds, too.
Besides what you heard, many new modules were in use:
The Yusynth (Yves Usson) Quad Voltage-Controlled panner was used throughout.
Also, used Yusynth Logic and Clock Dividers.
Used a pair of Voltage Quantizers from MFOS (Ray Wilson) -- not to mention my mighty 3 amp MFOS power supply.
Thank you for listening, providing support and encouragement for my DIY adventures, and for sharing your creativity in these online streaming events.
Description: |
The Aries patched up for the NYE 2011 streaming concert. |
Filesize: |
1.98 MB |
Viewed: |
636 Time(s) |
Description: |
My improvised set from New Years Eve to welcome 2011. |
Download |
Filename: |
NYE2011ElectroMusicSet_256.mp3 |
Filesize: |
107.45 MB |
Downloaded: |
2074 Time(s) |
_________________ -- Kevin
http://kevinkissinger.com |
klangumsetzer
Audio files: 32
Posted: Mon Jan 03, 2011 3:28 am Post subject:
thanks stefan for helping me out and streaming my prerecorded performance.!
the recurring text is from thoreau's 'walden':
"(...) But men labor under a mistake. The better part of the man is soon plowed into the soil for compost. By a seeming fate, commonly called necessity, they are employed, as it says in an old book, laying up treasures which moth and rust will corrupt and thieves break through and steal. It is a fool's life, as they will find when they get to the end of it, if not before. It is said that Deucalion and Pyrrha created men by throwing stones over their heads behind them:
Inde genus durum sumus, experiensque laborum,
Et documenta damus qua simus origine nati.
Or, as Raleigh rhymes it in his sonorous way,
"From thence our kind hard-hearted is, enduring pain and care,
Approving that our bodies of a stony nature are."
So much for a blind obedience to a blundering oracle, throwing the stones over their heads behind them, and not seeing where they fell. (...)"
wishing all a peaceful 2011
eike
Description: |
copyright 2011 klangumsetzer - licensed for listening via cc sa/by/nc |
Download |
Filename: |
klangumsetzer_e-m nye 2011.mp3 |
Filesize: |
27.47 MB |
Downloaded: |
1974 Time(s) |
djfoxyfox
Joined: Feb 05, 2003 Posts: 3228 Location: Nazareth, Pennsylvania, USA
Posted: Tue Jan 04, 2011 6:55 am Post subject:
EmeraldAdrift wrote: | Here's the Tensor Sensellation set. | Tensor Sensellation? That's a new one on me, Dave. Is this in addition to or a replacement of Emerald Adrift? How could I have gotten so out of touch? I see your Soundcloud profile has tracks that are seven months old. Please, do tell.
I plan to listen to your and other NYE tracks. Right now, I'm listening to Jez's track. On NYE, I was out in the real world filling in for a fiddle player in my friend's band. Actual income from making music! Can't beat that with a stick!
BTW1, © is available via <option>+G on a Mac. I wish that (P) wasn't left out by Apple. It would be a lot more useful to folks like us than ¬ (<option>+L), for example.
BTW2, a copyright notice doesn't need both the word and the symbol. Either will do. The proper form is:
Copyright year copyright-owner
or
© year copyright-owner
Example:
© 2011 Tensor Sensellation
All three elements must be in the proper order to be considered a proper copyright notice.
As a radio show host, I see many releases that forget to include a copyright notice or use it improperly by leaving off elements or arranging them in an improper order. Legally, people are leaving themselves open to theft of their music due to improper forms of the notice!
Cheers, _________________ Bill Fox------------------|\-------------
-----------()----soundscapes.us/bill |
Joined: Jan 07, 2009 Posts: 1196 Location: Scottish Borders
Audio files: 155
EmeraldAdrift
Posted: Sun Jan 09, 2011 11:46 pm Post subject:
djfoxyfox wrote: | EmeraldAdrift wrote: | Here's the Tensor Sensellation set. | Tensor Sensellation? That's a new one on me, Dave. Is this in addition to or a replacement of Emerald Adrift? How could I have gotten so out of touch? I see your Soundcloud profile has tracks that are seven months old. Please, do tell. |
Emerald Adrift = a solo project
Tensor Sensellation = a collaborative project with Damon Mar
Flute of the Fallen Tiger = a collaborative project with Palancar
mind8Spiral = a previous, collaborative project with Metlay! + Palancar
Infinity Sideways = a current, collaborative project with Metlay! + Palancar
Etc., etc. — got some more secrets up my sleeve for the future _________________ Emerald Adrift
http://soundcloud.com/emerald-adrift
Free albums at the Internet Archive |
fky
