March Equinox 2019 live streaming event
Page 2 of 2 [34 Posts]
Goto page: Previous 1, 2
Audio files: 278
PostPosted: Sat Mar 23, 2019 1:59 am    Post subject: Reply with quote  Mark this post and the followings unread
Ah, good you got it going and thanks for testing :-)
Audio files: 276
PostPosted: Sat Mar 23, 2019 11:24 am    Post subject: Reply with quote  Mark this post and the followings unread
Here's my set, for this one I used:
MODX6, Minilogue, OP-1, iPads (running Addictive, Cube, Nave and Poseidon), Joue controlling Micromonsta, cirklon, Model Ds for drones, TETR4 for sequences, processed by Mini KP, Zoom MS-CDR70s and Eventide Space and looped by DD-20 Smile
setup 1
 Filesize:  1.65 MB
 Viewed:  551 Time(s)
setup 2
 Filesize:  1.82 MB
 Viewed:  567 Time(s)
setup 3
 Filesize:  2.5 MB
 Viewed:  597 Time(s)
setup 4
 Filesize:  2.35 MB
 Viewed:  589 Time(s)
modulator_esp_e-m_spring_equinoxe_ostara_phase.mp3
Modulator ESP - electro-music Spring Equinoxe - Ostara Phase
 Filename:  modulator_esp_e-m_spring_equinoxe_ostara_phase.mp3
 Filesize:  55.48 MB
 Downloaded:  1165 Time(s)
Audio files: 278
PostPosted: Sat Mar 23, 2019 2:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
And my setness :-)
This was done with two Wren instances, using eight patches, and doing some mixing with the RME fireface, also using some reverb and echo on that one. Oh and compressed/limited a bit before going into the stream.
Edit: this was all tuned from an equal division in 19 parts of the tritave .. i.e. steps of 3^(1/19) instead of the usual 2^(1/12) .. those two are pretty much equal except in the first one the tritave is perfect (but not the octave (3^(12/19))) and in the second one the octave is, but not the tritave (2^(19/12))
But anyway .. the difference is very small, like 1 in 2000 or so for the octave.
2019-03-23--blue-hell--out-of-step.mp3
Blue Hell - out of step (march equinox 2019 performance)
 Filename:  2019-03-23--blue-hell--out-of-step.mp3
 Filesize:  54.65 MB
 Downloaded:  1168 Time(s)
Audio files: 155
PostPosted: Sat Mar 23, 2019 5:30 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi all , thanks for all organising & all who performed Smile
Here is the Epicyclus set , for today i used the blue modular , Ambika , waldorf pulse v1 , Juno-60 , yellow diy drum synth Smile Smile
EPICYCLUS Spring March 2019 EM concert.mp3
 Filename:  EPICYCLUS Spring March 2019 EM concert.mp3
 Filesize:  41.48 MB
 Downloaded:  1003 Time(s)
Audio files: 495
PostPosted: Sun Mar 24, 2019 9:50 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks to you all for being there and enduring me in the chat. Wink
My setup was a mix of hard and soft toys; Nord Lead 4, Digitakt, 0-coast through Mini Kaoss Pad 2, Kaoss Pad Quad, Aalto VST, Valhalla Plate and Ubermod - all run through or inside Plogue Bidule.
Plogue Bidule setup for March 2019 Equinox
 Filesize:  1.05 MB
 Viewed:  526 Time(s)
MarchEqui19_ML.mp3
Muied Lumens - March on Equinox 19
 Filename:  MarchEqui19_ML.mp3
 Filesize:  54.24 MB
 Downloaded:  1005 Time(s)
Acoustic Interloper
Audio files: 89
PostPosted: Sun Mar 24, 2019 12:08 pm    Post subject:
Subject description: Acoustic Interloper Set
The attached recording has the first 20 minutes of my March 23, 2019 equinox set (the processed guitar part), followed by another 20 minutes of processed acoustic banjo from this afternoon that replaces the 23rd's 10-minute banjo part.
I broke a picking fingernail in changing instruments yesterday at the 20 minute mark, had to play with the fleshy part of the finger because the nail was snagging, and it threw me off. The mix between banjo amplitude and soft synth amplitude was off, and even amplitude between picking fingers on the banjo, which is something I can't fix in real time.
This is better. I trimmed away the fingernail snag last night and played the banjo part just now for a full 20 minutes, the way God apparently intended. Twisted Evil I edited the 2 sections together with only small level adjustments.
Photo shows the instruments. First 20 minutes are my wife's G&L Ascari electric guitar, played through fx in Ableton Live (mostly delays). My son calls it my wife's metal guitar because the strings are so thick, which is how I like them; I like to lean into them, which is likely how I broke the nail. The last 20 minutes are my Bart Reiter Professional with a bright Bacon tone ring & an internal wooden resonator that acts as an EQ, bringing down the high end and adding a touch of sustain. I also used a Roland FC-300 controller's pair of expression pedals to control feedback and wet/dry on the delay fx. All picking was pickless finger up-picking, minus yesterday's snagged fingernail. Applied Acoustic Soft Synths under Live for the backing tracks include String Studio & Chromaphone.
Thanks, PHOBoS and everyone. I enjoyed listening, playing, and chatting!
My rig
 Filesize:  7.6 MB
 Viewed:  544 Time(s)
TakeCoverPart3March2019.mp3
Take Cover Part III, copyright Dale E. Parson, 2019, Creative Commons Attribution 4.0 International (CC BY 4.0), copy freely with attribution
 Filename:  TakeCoverPart3March2019.mp3
 Filesize:  57.8 MB
 Downloaded:  928 Time(s)
When the stream is deep
my wild little dog frolics,
when shallow, she drinks.
schugo
PostPosted: Mon Mar 25, 2019 4:01 am    Post subject:
Subject description: Schugosonic Equinox
OK... 7 hours before my stream event I made the stupid decision to rebuild the complete audio setup....
and bring in large pieces of scrap metal (2x cuts in the fingers)
-> treated (abused) with self made drum sticks and metallic bows
5 minutes before the stream the contact mic broke and I had to solder it + no plan.. but err.. a something more or less unlistenable acoustic research track was finally broadcast... LOL
 Filesize:  56.1 KB
 Viewed:  501 Time(s)
Schugosonic_2019_03_23_EMC_EQUINOX_ED.mp3
 Filename:  Schugosonic_2019_03_23_EMC_EQUINOX_ED.mp3
 Filesize:  49.8 MB
 Downloaded:  980 Time(s)
PostPosted: Wed Mar 27, 2019 1:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hello electro-moo-zik peoples... I listened to all the recordings (not live) and wanted to say it was most enjoyable and thank you and perhaps one day I shall get my shiznit together and play a set on some future equinox or solstice...
.:james:.
Acoustic Interloper
Audio files: 89
PostPosted: Thu Mar 28, 2019 6:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
.:james:.
On behalf of the performers, thanks
