Here's an idea...
Page 1 of 2 [36 Posts]
iPassenger
G2 patch files: 78
PostPosted: Sun Aug 05, 2007 10:54 am    Post subject: Here's an idea... Reply with quote  Mark this post and the followings unread
What if a number of us work together on a patch and variations. My idea is this, one of us, starts a patch with say 5 modules and wires however they see fit n then posts the patch up here, then someone else adds another 5 modules, re-patches and re-dials as they see fit and then post their version. We keep going, different people adding their own modules and touchs until there is no mem left.
(i think we would need to keep it mono)
What do u reckon?
Maybe we would need to agree a rough agenda for the patch (bass synth, sound fx, noodle etc)? And perhaps agree a number of members to take part (on a rota basis) or perhaps that each person only contributes one of the minor sections to the finished team effort (therefore we would need a lot of patchers involved)? Maybe 5 modules is too many, maybe it should be 3 or 4?
Just thought it might prove an interesting experiment and I am sure I might learn a thing or two in the process. Smile
R.
iP (Ross)
cebec
G2 patch files: 31
PostPosted: Sun Aug 05, 2007 12:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
I think it's a cool idea. Count me in!
G2DREAM
PostPosted: Mon Aug 06, 2007 10:30 am    Post subject: Reply with quote  Mark this post and the followings unread
Me too, I love this idea!
___________
cyber-evolution
Audio files: 278
PostPosted: Wed Aug 08, 2007 9:07 am    Post subject: Reply with quote  Mark this post and the followings unread
So where is the patch Laughing
I'm not set up yet (after Chateau Sonore), but sounds cool to me !
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Wed Aug 08, 2007 12:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
We did something like this during the top days of the NM Classic, only the rules were: Change one module and add one.
Wout
cebec
G2 patch files: 31
PostPosted: Wed Aug 08, 2007 12:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
Wout
What was the time limit on making one's changes? Was the patch saved as a unique patch each time or was the patch name kept the same?
iPassenger
G2 patch files: 78
PostPosted: Wed Aug 08, 2007 12:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
I just tried to post this and something went wrong, so am going try again.
As folks are keen to get started, lets just run with it and see what happens. You might say it is a modular approach, modifying as necessary.
Purpose:
Make ambient drone/noodle
Rules
1. Can add up to four modules (no less than 1), swapping a module for another counts as adding one.
2. Keep it mono.
3. May spread to performance if necesary.
4. This is a free for all no order of submissions, it if gets out of hand, we'll try and order next time.
5. you cannot modify again until two other people have modified it since your last modification.
Here is part one:
EDIT: No longer have this patch, sorry. Sad
iP (Ross)
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Wed Aug 08, 2007 1:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yes, the patches were saved as unique data, only, I can't find these anymore. Indeed, there were moments two or more participants send in a patch belonging to the same stage. So this is where the line will split...
Wout
(who is a couple of days off line)
iPassenger
G2 patch files: 78
PostPosted: Wed Aug 08, 2007 1:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yes i figured that this is a risk, which is why i sggest for the next one, we agree a running order and time limit.
iP (Ross)
cebec
G2 patch files: 31
PostPosted: Wed Aug 08, 2007 7:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
Here's my submission. I made a variation and added a notch filter set at 24 kHz to remove the 24 kHz control rate bleed which occurs under certain conditions, especially when using a control rate module as an audio source. This notch attenuates the bleed, a 'spike', by about 25 dB. I adapted this building block from some elliptical filter thingy. It adds about 4% memory and processor load. It can always be removed once there's more going on, etc.
team drone 2.pch2
 Filename:  team drone 2.pch2
 Filesize:  1.24 KB
 Downloaded:  2243 Time(s)
Audio files: 278
PostPosted: Sat Aug 11, 2007 12:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
Added a frequency doubler (one and a half actually) and a filter.
team_drone_3.pch2
 Filename:  team_drone_3.pch2
 Filesize:  1.46 KB
 Downloaded:  2357 Time(s)
iPassenger
G2 patch files: 78
PostPosted: Sun Aug 12, 2007 4:19 am    Post subject: Reply with quote  Mark this post and the followings unread
more lfos and some noise, wanted to patch it in to the audio stream as well but ran out of modules.
EDIT: No longer have this patch either, damn, I am too delete happy. Sorry folks.
iP (Ross)
Audio files: 278
PostPosted: Sun Aug 12, 2007 3:30 pm    Post subject: Reply with quote  Mark this post and the followings unread
Nice one, can hardly wait to do a little to it Very Happy
dasz
Audio files: 29
G2 patch files: 56
PostPosted: Sun Aug 12, 2007 10:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
ok, my small contribution from the sequencer dept. the lookup sequencer concept may be familiar to some folks (who attended EME 2007).
No longer a drone I am afraid. Play at 120.
I like this idea of bouncing patches off-of each other. I always like that stuff, too bad it has not been more prevalent around here.
/Dasz
(note: restored the patch - Blue Hell)
team_drone_dz_490.pch2
 Filename:  team_drone_dz_490.pch2
 Filesize:  3.07 KB
 Downloaded:  1693 Time(s)
Audio files: 278
PostPosted: Mon Aug 13, 2007 11:37 am    Post subject: Reply with quote  Mark this post and the followings unread
erm ...
Rules
Shocked
iPassenger
G2 patch files: 78
PostPosted: Mon Aug 13, 2007 12:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
Laughing
Nice patch tho.
They do say that rules are meant to be broken. 4 from now on. Exclamation Wink
So who's next?
iP (Ross)
dasz
Audio files: 29
G2 patch files: 56
PostPosted: Mon Aug 13, 2007 12:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
erm ...
Rules
Shocked
Smile
Rule 6. Rules are guidelines, and may be broken in case of emergency.
Maybe we could allow to branch the patches like you would branch code.
Anyway, I should have read the rules. Next time. Embarassed
/Dasz
Audio files: 278
PostPosted: Tue Aug 14, 2007 5:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
Shocked Laughing
team_drone_5.pch2
 Filename:  team_drone_5.pch2
 Filesize:  3.04 KB
 Downloaded:  2263 Time(s)
Audio files: 213
PostPosted: Tue Aug 14, 2007 6:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
team_drone_5_169-1.pch2
 Filename:  team_drone_5_169-1.pch2
 Filesize:  3.46 KB
 Downloaded:  2547 Time(s)
Fozzie
G2 patch files: 49
PostPosted: Wed Aug 15, 2007 12:39 am    Post subject: Reply with quote  Mark this post and the followings unread
Cool topic
added 1, modded 3
team_drone_6.pch2
 Filename:  team_drone_6.pch2
 Filesize:  3.55 KB
 Downloaded:  1722 Time(s)
iPassenger
G2 patch files: 78
PostPosted: Wed Aug 15, 2007 10:25 am    Post subject: Reply with quote  Mark this post and the followings unread
Awesome.
iP (Ross)
iPassenger
G2 patch files: 78
PostPosted: Thu Aug 16, 2007 11:31 am    Post subject: Reply with quote  Mark this post and the followings unread
OK, so i am getting a bit lost now, so I just added some effects to space it out a bit.
And another variation, which i thought was a bit more spacey (just chanegd wiring and dials a bit on my first patch):
Don't believe i mentioned vars in the rules. ?
team_drone_7.pch2
 Filename:  team_drone_7.pch2
 Filesize:  3.92 KB
 Downloaded:  1751 Time(s)
team_drone_7_222.pch2
 Filename:  team_drone_7_222.pch2
 Filesize:  3.92 KB
 Downloaded:  1782 Time(s)
iP (Ross)
iPassenger
G2 patch files: 78
PostPosted: Thu Aug 16, 2007 11:42 am    Post subject: Reply with quote  Mark this post and the followings unread
/Dasz
Slightily off topic, so please don't mod this one but... attached a variation i did of this version before it got so mental. still play at 120.
team_drone_dz_499.pch2
 Filename:  team_drone_dz_499.pch2
 Filesize:  3.07 KB
 Downloaded:  1663 Time(s)
iP (Ross)
Audio files: 278
PostPosted: Thu Aug 16, 2007 6:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
Some great patches you people posted !
When I started my mod I lost track of what everything was doing after I added my four modules. So I totally deconstructed the thing and then rebuilt to attached. Some modules were left unused maybe they should have been deleted but I'm not sure about the deletion rules ...
team_drone_7_222_195-4.pch2
 Filename:  team_drone_7_222_195-4.pch2
 Filesize:  4.54 KB
 Downloaded:  2503 Time(s)
cebec
G2 patch files: 31
PostPosted: Fri Aug 17, 2007 8:12 am    Post subject: Reply with quote  Mark this post and the followings unread
I changed one Osc to reduce DSP, added a Glide module, and changed some routings and settings.
Heh, I'm also finding it difficult to keep track of what I'm doing once I get going.
team_drone_8.pch2
 Filename:  team_drone_8.pch2
 Filesize:  4.64 KB
 Downloaded:  2285 Time(s)
