G2 RACE encoder
Page 2 of 2 [29 Posts]
Goto page: Previous 1, 2
durwood
PostPosted: Fri Apr 25, 2008 10:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
elektro80 wrote:
Ignore that one. It seems Plogue Bidule is dead. Nothing seems to have happened there since 2005/2006.
Ahoy. I've been trying to track down as much info on the ambiophonic playback system and I see this is gaining momentum here. I've been experimenting with what's already available and doing lots of research. You mentioned Plogue Bidule is dead. That is not entirely true. I think the people using it went off elsewhere but it's alive and kicking by a few experienced people.
lot's of work was done with this at doom9.org.
http://forum.doom9.org/showthread.php?t=83752
I was late to that party, but one of the gurus left and formed his own place.
www.dtsac3.com
Lot's of Bidule use there. Wink Maybe this will help you guys? I'm trying to find the VST that gives the best results so I don't trying to help where I can. Unfortunately I'm of no use in Reaktor, but I've gathered alot of info on this subject and related subjects as well and can try to provide links. Let me know if I can help or am of any use.
bachus
PostPosted: Sat Apr 26, 2008 4:42 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for the tips and welcome to electro-music. Very Happy
bachus
PostPosted: Sun Apr 27, 2008 10:17 am    Post subject: Reply with quote  Mark this post and the followings unread
durwood (in another forum) had asked about the role of the filters in the race encoders. They are simple one or two pole HP and LP filters which separate the portion of the spectrum that is to be encoded from that which is not.
 Filesize:  40.48 KB
 Viewed:  843 Time(s)
BobTheDog
PostPosted: Wed Jul 16, 2008 9:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
It isn't dead!
There have been various updates, the last was only three days ago.
