  Muied Lumens Frequencies
 Forum index » Clavia Nord Modular » G2 Patches - Completed » Sequencer - interactive
detritus
Page 1 of 1 [2 Posts]
egw
G2 patch files: 8
PostPosted: Fri Oct 22, 2004 3:44 pm    Post subject: detritus Reply with quote  Mark this post and the followings unread
Detritus is a pattern based sequencer. It uses the pattern generator to play sequences of any length from 1 to 128 steps. There is also a separate pattern for the rhythmic feel.
The knob assignments are as follows:
Row A: real time controls - filters and levels for sequence and drum.
There is also a global transpose that lets you toggle an interval.
The button toggles and the knob sets the interval.
Row B: sequence setup - key, complexity, octave, range, length, pattern
The key is one of 8 minor keys - D,E,G,B,C,C#,D#
It's easy to customize other keys.
Complexity is the number of different notes in that key that can be played.
The pattern can be selected with the knob or randomly changed with the dice button. Patterns selected with the dice can't be saved.
Row C: sound - oscillators and envelopes
Row E: delay controls (the default is 1/8D)
Volume is down when the patch is loaded. The variations select 8 different keys.
detritus.pch2
 Filename:  detritus.pch2
 Filesize:  4.63 KB
 Downloaded:  2117 Time(s)
Audio files: 153
PostPosted: Fri Oct 22, 2004 4:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hey, this sounds like you are here in the studio with me, only you aren't. Cool Very Happy
