Radio is down?
Page 1 of 1 [8 Posts]
PostPosted: Fri Jul 14, 2017 9:33 am    Post subject:  Radio is down? Reply with quote  Mark this post and the followings unread
Thought I'd do some silly streaming, couldn't connect so I checked the radio page and everything seems to be offline... scheduled maintenance or a crash somewhere?
Audio files: 705
PostPosted: Fri Jul 14, 2017 11:00 am    Post subject: Reply with quote  Mark this post and the followings unread
ports where all stopped so there probably was some crash. I restarted them (not all private ports yet)
which doesn't seem to bring back the radio channels so I am looking into that. The private ports seem
to work though and they can probably be switched to main if you want that.
Audio files: 705
PostPosted: Fri Jul 14, 2017 11:02 am    Post subject: Reply with quote  Mark this post and the followings unread
hmm I think I am not the only one doing something with it as some ports are restarted but not by me. Very Happy
Audio files: 278
PostPosted: Fri Jul 14, 2017 11:06 am    Post subject: Reply with quote  Mark this post and the followings unread
Oh dear ... let me fix ...
Audio files: 705
PostPosted: Fri Jul 14, 2017 11:09 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks jan, looks like you fixed it Very Happy
Audio files: 278
PostPosted: Fri Jul 14, 2017 11:10 am    Post subject: Reply with quote  Mark this post and the followings unread
ok, fixed.
There was an automatic system reboot, and the sc_trans stuff unfortunately needs a manual start after that.
PostPosted: Fri Jul 14, 2017 11:24 am    Post subject: Reply with quote  Mark this post and the followings unread
Nice rescue squad! Very Happy
Audio files: 278
PostPosted: Fri Jul 14, 2017 11:40 am    Post subject: Reply with quote  Mark this post and the followings unread
Hhe .. I've just now tried to add it to a startup script .. lets see next time what happens .. the sc_serv stuff still has to be started manually .. as I have no idea how to automate that Shocked but at least every stream op can start those from the switcher page - with ' start all'
So I hope this will help.
