Joined: Apr 03, 2004 Posts: 24085 Location: The Netherlands, Enschede
Audio files: 278
Posted: Sun Jun 03, 2007 1:04 pm Post subject:
Re: Sequencer restarts unexpectedly on variation change |
Antimon wrote: | Now I'll have to click manually in every damn sequencer |
Can't you automate it with some MIDI modules ? Without using morphs I mean, but directly on the limit, sending changes only and nothing when no change occurs. _________________ Jan
dasz
Joined: Oct 16, 2004 Posts: 1644 Location: victoria, canada
Audio files: 29
G2 patch files: 56
Posted: Wed Jun 13, 2007 8:45 am Post subject:
This is a bug IMHO. The NM1 did not have such behavior, neither does an analog sequencer (in a Moog modular, or a Roland System 100).
The only time a sequencer should restart is when you reset it explicitly, or the current steps exceeds the loop length (if loop is turned on).
This "bug" wreaks havoc in a live situation, when you are trying to tweak sequencer lengths, or in your situation change variations.
A workaround is to use a 2nd gate sequencer, and use it's gate output to reset it and the 1st sequencer at the desired step length. Sequencer 1's loop setting should be turned off.
/Dasz |
audible
Posted: Sat Jun 23, 2007 12:26 am Post subject:
dasz wrote: | The only time a sequencer should restart is when you reset it explicitly, or the current steps exceeds the loop length (if loop is turned on).
I agree. I was trying to replicate a Doepfer MAQ (sold recently) on the G2 and this was a major drawback. Changing sequence length on the fly is vital for me.
dasz wrote: | A workaround is to use a 2nd gate sequencer, and use it's gate output to reset it and the 1st sequencer at the desired step length. Sequencer 1's loop setting should be turned off.
Could you elaborate on that? A little patch would be extremely useful for us noobs. Thanks. |
Posted: Sat Jun 23, 2007 4:36 am Post subject:
I would like to stress that we are talking about two different bugs here. The original one (sequencer resets when you change length) I've personally learned to live with.
The second (that I wrote about in my first post in this topic) is that in some cases the sequencer restarts when you change variation even if there is no change in length. This happens if you have assigned a morph to the length. When you change variation, the sequencer restarts even if the morph stays at the same value. This is a bug that cannot be justified in any way, IMHO.
dasz
Audio files: 29
G2 patch files: 56
Posted: Sat Jun 23, 2007 7:32 am Post subject:
I see. that is bad. I hope this is fixed at the same time as the loop length reset issue. |
