Breaking glass
Page 1 of 1 [6 Posts]
Audio files: 278
PostPosted: Sat Mar 11, 2006 9:37 pm    Post subject: Breaking glass Reply with quote  Mark this post and the followings unread
I've been working a bit on breaking glass, soundwise. It's not really breaking glass that I'm after, as I want it to have some tonality, it should play some melody, but that's secondary.
Anyway, here is a patch I came up with. It's pretty lame though, it does have some glass like features in it I think but it's more like a mix between a zipper and a steel drum still.
Any suggestions ?
I found this, pdf on the web, not sure if its helpfull as I've only read the first few paragraphs sofar.
br_glass_01.pch2
in search for breaking glass
 Filename:  br_glass_01.pch2
 Filesize:  2.81 KB
 Downloaded:  2474 Time(s)
ian-s
Audio files: 42
G2 patch files: 626
PostPosted: Sun Mar 12, 2006 12:52 am    Post subject: Reply with quote  Mark this post and the followings unread
Taken from an old prf, not so much designed as stumbled upon, it is a descendant of my tambourine patch. Not easy to impart tonality without breaking the effect.
glassBreak.pch2
glass breaking
 Filename:  glassBreak.pch2
 Filesize:  1.79 KB
 Downloaded:  1846 Time(s)
Audio files: 278
PostPosted: Sun Mar 12, 2006 9:47 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks, sounds like glass alright, I'll see what I can make out of it.
3phase
G2 patch files: 141
PostPosted: Mon Mar 13, 2006 6:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
I once made a sound with a sampler that had a glass tonality...
The recording was made with the rest of a bottle smashin session just as a secondary try... i stired with a stick thru the debree auf the smashed bottles ... the clicking and falling around each other of the glaspieces gave a very nice atmospheric loop that had acousticaly 100% glass identity ...
you allways was reminded to breaking glas by the sound..but it wasnt a percussiv or explosiv event...rather hundrereds of microglasbreaks...
Granular sampling ...stirring in glas grains... If this is from interest for you i maybe can locate the tape...
Audio files: 278
PostPosted: Mon Mar 13, 2006 7:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'm always interested in hearing a little sample. But you gave me a new idea to try already - maybe I can send Ian's patch (or a couple of 'm) through Tim's delay magic.
I've tried filters sofar and the vocoder, but those kill the glass aspect, nothing but sad noise bursts remains. And then I got distracted by some mad noodle :-)
Audio files: 278
PostPosted: Mon Mar 13, 2006 7:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
The glass aspect stays better, but Ian may be right, hard to make it tonal - it seems inherently noise ...
glass_02.pch2
Another go at glass, breaking
 Filename:  glass_02.pch2
 Filesize:  4.85 KB
 Downloaded:  2435 Time(s)
