vladosh
Audio files: 46
Posted: Tue Sep 24, 2019 8:04 am Post subject:
i print it on aluminum at a printing house ,drilled it myself _________________ http://synthacks.blogspot.com/ шематикс |
Posted: Fri Oct 11, 2019 3:09 pm Post subject:
LFLabs, finally finished those VCAs you sent me
And this last photo is for Dave Skrog --
cslammy
Posted: Mon Oct 14, 2019 6:55 am Post subject:
Yeh!! I've built the FEITW circuit many times now. Rene should get nominated for a noble prize, this is a fantastically great sounding ADSR!!! _________________ Visit my AUDIODIWHY blog and website |
Posted: Fri Nov 01, 2019 7:24 pm Post subject:
Eurorack copy of the Buchla 258 Dual Oscillator. Very easy to get a good sound out of this.
This particular PCB set uses the THAT340 transistor array, working off Mark Verbos' annotated schematic. I've got a set of PCBs that use BC8x7DS matched pairs instead (cheaper), and will verify them in a few days. |
Posted: Sun Nov 03, 2019 9:19 pm Post subject:
Arpad Benares' touch controller from Synapse Magazine. This was a pseudonym for Serge, and it's a very responsive touch controller indeed!
Provided, of course, that I don't screw up. I had three resistors in the small oscillator going to ground, and not -12V, and I ran out of 22M resistors (hence the two in parallel on the back. I also had the ICs far too close to the header pins, and had to actually slide them forward as much as the sockets would let me. To do this, I had to desolder the power smoothing caps and angle them forward a bit. |
LektroiD
Joined: Aug 23, 2008 Posts: 1019 Location: Scottish Borders
Audio files: 705
Posted: Sat Nov 23, 2019 1:15 pm Post subject:
Voiced/Unvoiced Detector, built from the Doepfer module's schematics. Originally did this for someone in 2017, finally got around to building one for myself.
I think the wires for the pots was why I put it off. I can do crimped connectors... they're just a fiddly pain in the posterior to actually do, for me. |
kaputtpanzer
Audio files: 15
Posted: Tue Dec 10, 2019 6:03 am Post subject:
I showed that one before, but now it got a frontpanel. Design wise it is still not finished. At first sight I was really satisfied with the edges, but then I decided to try out rounded edges on other boards and I liked it more. So I will make another run of pcbs and panels I guess
Description: |
Filesize: |
205.36 KB |
Viewed: |
264 Time(s) |
Description: |
Filesize: |
336.17 KB |
Viewed: |
261 Time(s) |
cslammy
richardc64
Audio files: 26
cslammy
Posted: Wed Jan 15, 2020 7:34 am Post subject:
AlanP wrote: |
Finished it Mutable Shruthi XT, with Polivoks filter. Some LEDs arrived from Dave, so I was able to button this up.
Nice synth. |
Looks great alan P! How did you do the front panel graphics? _________________ Visit my AUDIODIWHY blog and website |
cslammy
Posted: Wed Jan 15, 2020 7:38 am Post subject:
AlanP wrote: | 'Analog Monster' is pretty well bang on for you and your amazing projects, Carsten |
Ditto that. Very impressive work. _________________ Visit my AUDIODIWHY blog and website |
cslammy
Posted: Wed Jan 15, 2020 7:40 am Post subject:
AlanP wrote: |
Great work again Alan P. If you have any PCBs left over and want to sell 'em please PM me. Thanks _________________ Visit my AUDIODIWHY blog and website |
cslammy
Posted: Wed Jan 15, 2020 8:36 am Post subject:
cslammy wrote: | AlanP wrote: | Finished it Mutable Shruthi XT, with Polivoks filter. Some LEDs arrived from Dave, so I was able to button this up.
Nice synth. |
Looks great alan P! How did you do the front panel graphics? |
I got the case from Rob Hallik. |
sompost
Posted: Tue Mar 24, 2020 3:37 am Post subject:
LektroiD wrote: | System 100 clone, built with Pharmasonic PCBs... |
Wow, that's a neat little instrument!
The leftmost bottom panel (labelled "computer") is a non-standard (USB-)MIDI unit, isn't it. Where did you get that from?
Cheers and a lot of fun! _________________ Built: MFOS SLMS plus, SL Ultimate & Expander, 10 step seq; SLMS MkII; PAiA FatMan, Mutable-Instruments Shruthi-1; Jasper Wasp Clone
Backlogging: MFOS 16 step seq; TH SN Voice; Takeda One Board Farm; Okita Vocoder; Page TR-9090; TH GM Voice, AY Voice |
Joined: Nov 23, 2015 Posts: 1295 Location: Netherlands
Posted: Sun Mar 29, 2020 12:47 pm Post subject:
Drum sequencer, first 4 channels pure digital, the next 4 are outputs of a quad 16bit DAC.
Module is powered by a bluepill STM32F103.
Description: |
Filesize: |
1.94 MB |
Viewed: |
89 Time(s) |
Description: |
Filesize: |
2.97 MB |
Viewed: |
89 Time(s) |
Description: |
Filesize: |
1.28 MB |
Viewed: |
94 Time(s) |
_________________ my synth |
Audio files: 705
Posted: Mon Mar 30, 2020 2:27 pm Post subject:
For the digital outputs I just use a 74LS08, works perfectly.
For the last 4 channels I use a quad DAC which accepts 3.3 volt digital signal, and puts out 0 to 5 volt. The rest of the components like the display etc. are 3.3 volt compatible.
At the moment I’m working on the software, when that works I will open a thread with schematics and some explanation how things work.
For this project I use the Arduino IDE.
I just realise that I just have outputs and no inputs... guess I have to make a secondary panel with trigger in and outputs...😱 _________________ my synth |
Audio files: 705
Posted: Mon Mar 30, 2020 3:37 pm Post subject:
oh interesting, I just checked the datasheet for the 74LS08 and it says the mininum high voltage level is 2V. yeah that'll work, cool
Did you get the arduino IDE working with USB ? I did manage to upload a sketch through FTDI but haven't been able to load an arduino bootloader on it.
and yeah, I did notice the lack of inputs, and the fancy goldplated connectors _________________ "My perf, it's full of holes!"
Audio files: 705
Posted: Tue Mar 31, 2020 7:21 am Post subject:
Thanks.
I have one those too but since I wasn't 100% sure if it would work and didn't want to risk having to wait another month or so
I also ordered one of those FTDI boards right away, which I believe was only $0,75. But good to know that one works too.
Yeah the blue pill boards are damn cheap and with those specs a nano doesn't even come close but I do like the convenience
of only needing a USB cable and not having to mess around with different voltages and/or jumper settings.
One more question before I derail this thread too much; why the red buttons in those places, was that purely an aesthetic choice ? _________________ "My perf, it's full of holes!"
Posted: Tue Mar 31, 2020 8:44 am Post subject:
I plan to have midi implemented as well, and the buttons can serve as a keyboard input (could have used black caps instead of the red ones )
And the “fancy” gold plated connectors are the same price as the metal ones and are there to discriminate between triggers and analog outputs. _________________ my synth |
Audio files: 705
Posted: Tue Mar 31, 2020 11:29 am Post subject:
ah that makes sense. I was looking at it as a drum controller and it made more sense to me to use them for steps 1,5,9,13.
It does remind me of a MIDI controller I made in 2013 but never completely finished and I don't think I ever posted any photos before.
It is functional though and I used it to create some tracks which you can find here.
Description: |
Filesize: |
203.56 KB |
Viewed: |
91 Time(s) |
Description: |
Filesize: |
207.19 KB |
Viewed: |
96 Time(s) |
Description: |
Filesize: |
213.11 KB |
Viewed: |
84 Time(s) |
Description: |
Filesize: |
174.87 KB |
Viewed: |
93 Time(s) |
Description: |
Filesize: |
286.56 KB |
Viewed: |
92 Time(s) |
